*morphshapelinkedpush
Adds a shape and a multiplier to a list of shapes to be used by *morphshapelinkedapply.
*morphshapelinkedpush shape_id mult
HyperMesh Tcl Modify Command
This command will add the specified shape to an internal list along with the multiplier for the shape which you wish to apply. The list may contain one or more shapes. Calling the command *morphshapelinkedapply will apply all the shapes on the list at their specified multiplier values. It will also apply any shapes linked to the applied shapes via desvar, deqatn, and dlink2 cards, such as those created during non-linear design variable generation. Calling *morphshapelinkedapply will clear the internal list of shapes and multipliers.
shape_id
The ID of the shape to add.
mult
The multiplication factor for the shape.
To mark shape ID 3 with multiplier of 0.5:
*morphshapelinkedpush 3 0.5
   # Handle error
Version History
11.0
