*compactsubmodelids
Renumbers ID ranges starting from the minimum allowed ID.
*compactsubmodelids submodel_id id entity_type ?pool_id?
HyperMesh Tcl Modify Command
submodel_type
Submodel type to compact the IDs for. Valid values are includes and includefiles.
id
The ID of the submodel.
entity_type
The type of entity to compact the IDs for.
0 - all entity types in the submodel are considered.
pool_id
The optional ID of the solver pool.
Examples
To compact component IDs in include file 1:
*compactsubmodelids includes 1 comps
To compact all entity type IDs in include file 1:
*compactsubmodelids includes 1 0
   # Handle error
Version History
12.0.110
2019 - Added new optional argument pool_id.
