*visualizemode
Sets the parameters for visualization mode.
*visualizemode hiddenline fillmode meshmode plot
HyperMesh Tcl Modify Command
hiddenline
Set to 1 for hidden line, 0 for wire frame.
fillmode
Set to -2 for contours, -1 for element color, or 0-15 for constant color.
meshmode
plot
Set to 1 to replot the screen after this command has executed, otherwise 0.
This command is valid only after the system has entered into visualization mode.
None.
