*interfaceadd
Creates interface elements.
*interfaceadd name master type mark reverse
HyperMesh Tcl Modify Command
name
The name of the group into which the interface elements should be placed.
master
Use 1 for master; 0 for slave.
type
The entity type of the slave entities (none, elements, nodes).
mark
The ID of the mark containing the nodes or elements which should have slave or master elements placed on them.
reverse
A logical which determines if the slave elements should be reversed when created.
None.
