*graphimport_file
Imports a mesh stored in HDF5 into the graphics.
*graphimport_file filename
HyperMesh Tcl Modify Command
filename
The full path and filename of the HDF5 mesh file.
Examples
To impor the C:\temp\mesh.hmg file:
*graphimport_file "C:/temp/mesh.hmg"
   # Handle error
Version History
2019
