*morphconstraintcreateline
Creates a line type morphconstraint for the selected nodes with the option of having those nodes either move along the line or be bounded by it.
*morphconstraintcreateline ntype nmark type name vec line dist ivec color
HyperMesh Tcl Modify Command
This command creates a line type morphconstraint for the selected nodes with the option of having those nodes either move along the line or be bounded by it.
ntype
Must be set to nodes.
nmark
The ID of the mark for the constrained nodes. Valid values are 1 and 2.
type
0 - Moves along the line
1 - Bounded by the line
3 - Remains a set distance from the line
5 - Remains its original distance from the line
+32 - Enable mesh stretching around constrained nodes. Add this value to the type (thus 1, 3, and 5 become 33, 35, and 37).
name
The name of morph constraint.
vec
The ID of the vector created using *createvector. Must be set to 1.
line
The ID of the line.
dist
The minimum distance from the bounding line.
ivec
0 - The line normal is used for distance and projection. The nodes will be moved normally to the line when constraining them or measuring the distance the nodes are away from the line.
1 - The vector is used for distance and projection. The nodes will be moved along the vector when constraining them or measuring the distance the nodes are away from the line.
color
The color of the constraint. Valid values are 1 through 64.
To create a morphconstraint for nodes to move along a line and projected normally to the line:
*createmark nodes 1 1 2 3 4 5
*createvector 1 1.0 0.0 0.0
*morphconstraintcreateline nodes 1 0 "line" 1 12 0.0 0 32
   # Handle error
