*systemcreate3nodes
Creates a rectangular coordinate system.
*systemcreate3nodes type origin axisname axispt planename planept
HyperMesh Tcl Modify Command
type
The type of system being created.
0 - rectangular
1 - cylindrical
2 - spherical
origin
The ID of a node which defines the origin.
axisname
A string which identifies the axis being defined with the next parameter (x, y, or z).
axispt
The ID of a node which defines a point on the axis defined by axisname.
planename
A string which identifies the plane being defined with the next parameter (xy, xz, or yz).
planept
The ID of a node which defines a point on the plane defined by planename.
To build a cylindrical system with node 1 defining the origin, node 2 defining the x axis, and node 3 defining the xy-plane:
*systemcreate3nodes(1,1,x,2,xy,3)
None.
