*createfbddisplacementtable
Creates an FBD displacement summary table.
*createfbddisplacementtable set_ids=<value> subcase_ids=<value> data_strings=<value> num_strings=<value>
HyperMesh Tcl Modify Command
This queries the GPF, Applied, SPC and MPC data from the result entity on a freebodysection.
Options can be provided in any order.
set_ids=<value>
The set entity IDs.
subcase_ids=<value>
The subcase info as an array. Values are specified as resultfile_id subcase_id step_id, with each list separated by a comma. For example: 1 1 0, 1 2 0, 2 1 0, 2 1 1.
The ID of the string array that contains the additional input parameters. The string array is created using the *createstringarray command. This should always be set to 1.
Valid parameters and their syntax are:
displacement=<value>
0 - Applied forces are not particupating in the FBD calculation (default)
1 - Applied forces are particupating in the FBD calculation
freenode=<value>
Currently must be set to 2. This is a mandatory argument.
resolvein_sys=<value>
0 - Resolve in analysis system (default)
1 - Resolve in global system
2 - Resolve in user system
resultid=<value>
The result entity ID.
rotation=<value>
0 - SPC forces are not particupating in the FBD calculation (default)
1 - SPC forces are particupating in the FBD calculation
tolerance=<value>
The tolerance to limit the values. Default is 0.00001.
user_sys_id=<value>
The system ID when resolvein_sys=2.
num_strings=<value>
Integer indicating the size (number of strings) in the data_strings array.
To create an FBD displacement summary table:
*createstringarray 7 "resultid=1" "resolvein_sys=3 " "user_sys_id=2" "displacement=1" "rotation=1" "freenode=2" "tolerance=0.00001"
set setIds {1 2 3}
set scIds {1 1 0, 1 2 0, 2 1 0, 2 1 1}
*createfbddisplacementtable $setIds $scIds 1 7
   # Handle error
Version History
2019.1
