*surfacemarksplitwithplane
Splits a group of surfaces with an infinite plane.
*surfacemarksplitwithplane mark plane
HyperMesh Tcl Modify Command
mark
The ID of the mark containing the surfaces.
plane
The plane used to split the surfaces.
To split surfaces 10 and 20 with the xy plane (normal equals the z-axis):
*createmark(surfaces,1) 10 20
*createplane(1,0.0000,0.0000,1.0000,0.0000,0.0000,0.0000)
*surfacemarksplitwithplane(1,1)
None.
