*surfacesplineonnodesloop2
Creates a spline surface using a node list as boundary conditions.
*surfacesplineonnodesloop2 list_id options
HyperMesh Tcl Modify Command
list_id
The ID of the list containing the input nodes. Valid values are 1 and 2.
The nodes should be selected in an order consistent with the intended trimming boundary of the constructed surface. No attempt is made to correct the input by rearranging the order of the nodes.
options
If set to 0, input nodes that were not already associated to any geometry get associated to the new surface. In addition, in simultaneous meshing modes set by *surfacemode, input nodes are taken into account to create connections between the new surface mesh and an already existing mesh.
If set to 1, input nodes are not associated to the new surface and are not taken into account in simultaneous meshing modes.
To build a spline from the nodes 1, 2, 3 and 4:
*surfacemode 1
*createlist nodes 1 1 2 3 4
*surfacesplineonnodesloop2 1 0
   # Handle error
Version History
14.0
