*mechimportdaf
Imports the dummy angle file for the current dummy.
*mechimportdaf filename
HyperMesh Tcl Modify Command
The mechanism must have the enabled flag set to true for this to be possible.
filename
The full name and path of the file to import.
To import the current dummy DAF file as C:/temp/dummy.daf:
*mechimportdaf "C:/temp/dummy.daf"
   # Handle error
Version History
14.0.120
