*CE_AddLinkEntities
Update connectors with entities.
*CE_AddLinkEntities connector_mark_id entity_type entity_mark_id
HyperMesh Tcl Modify Command
This command updates connectors with entities.
connector_mark_id
The ID of the mark containing the connectors to update. Valid values are 1 and 2.
entity_type
Type of entity to be added to the connectors as links.
entity_mark_id
The ID of the mark containing the entities to use as links. Valid values are 1 and 2.
Examples
To add comps 1 and 2 as to connectors 1-3:
*createmark connectors 1 1-3
*createmark comps 1 1 2
*CE_AddLinkEntities 1 comps 1
   # Handle error
