*setcolor
Set a colormap entry for the entity colors.
*setcolor index red green blue
HyperMesh Tcl Modify Command
index
Specifies the color location (0 to 63)
red
The red component of the color. ( 0 through 255)
green
The green component of the color. ( 0 through 255)
blue
The blue component of the color. ( 0 through 255)
The changes do not take effect until you redraw the display.
None.
