*blockwalleditrange
Adds or deletes a range of cells in a finite difference wall.
*blockwalleditrange blockname wallname imin imax jmin jmax kmin kmax del
HyperMesh Tcl Modify Command
blockname
The name of the block.
wallname
The name of the wall to be edited.
imin
The minimum value in the i direction, inclusive.
imax
The maximum value in the i direction, inclusive.
jmin
The minimum value in the j direction, inclusive.
jmax
The maximum value in the j direction, inclusive.
kmin
The minimum value in the k direction, inclusive.
kmax
The maximum value in the k direction, inclusive.
del
0 - Adds cells.
1 - Deletes cells.
