*morphsymmetryupdateaxis
Update one symmetry.
*morphsymmetryupdateaxis symptr sysptr domaintype markdomain enforce multilat type ucyc orient mv
HyperMesh Tcl Modify Command
symptr
ID of symmetry.
sysptr
ID of system.
domaintype
Domains
markdomain
Domain mark number.
enforce
0 = approximate
1 = enforced
multilat
0 = unilateral
1 = multilateral
type
Type of symmetry.
ucyc
Number of cycles for cyclical symmetry.
orient
0 = default
1 = x-axis
2 = y-axis
3 = z-axis
mv
0 = do not apply to morph volumes
1 = apply to morph volumes
*morphsymmetryupdateaxis (3,11,DOMAINS,1,1,1,10,3,0,0)
Symmetry will be updated to specified system and values. All domains on mark will be updated to use the selected symmetry.
None.
