*hf_ScaleBinderSurf
Scale the binder dimension. The binder is automatically identified.
*hf_ScaleBinderSurf base_point_id scale_factor_x scale_factor_y scale_factor_z
HyperMesh Tcl Modify Command
This command increases and decreases the binder dimension. The binder is scaled relative to an origin node. The scaling can be uniform or not. If uniform scaling is requested, the scale factor in all directions should be set equal. Otherwise, it is possible to give different value to these factors in other to obtain a non-uniform scaling.
base_point_id
The node ID to use as the base point for the scaling.
scale_factor_x
Scale factor in x.
scale_factor_y
Scale factor in y.
scale_factor_z
Scale factor in z.
Examples
To increase the binder dimension uniformly by a factor of 5 with respect to node ID 1434:
*hf_ScaleBinderSurf 1434 5 5 5
To decrease the binder dimension by a factor of 5 in the x, 10 in the y and 20 in the z with respect to node ID 1434:
*hf_ScaleBinderSurf 1434 0.2 0.1 0.05
   # Handle error
Version History
10.0
