*hwCfdSceneReverseAll
Reverses the display of all the entities of a given entity type.
*hwCfdSceneReverseAll entity_type ?consider_geom? ?consider_elems?
HyperMesh Tcl Modify Command
This command is used to reverse the display of a mark of entities of a given entity type.
This should be used in conjunction with the *hwCfdSceneShowHideIsolateEntity and *hwCfdSceneShowAll commands.
This command is valid only for the CFD profile.
entity_type
The type of entity to modify. Valid values are modules, regions, surfaces and solids.
consider_geom
0 - Do not consider the associated geometry
1 - Consider the associated geometry (default)
consider_elems
0 - Do not consider the associated elements
1 - Consider the associated elements (default)
Examples
To hide surfaces 1-10, reverse the display, then show all entities:
*createmark surfaces 1 1-10
*hwCfdSceneShowHideIsolateEntity hide surfaces 1 1 1 1
*hwCfdSceneReverseAll surfaces 1 1
*hwCfdSceneShowAll 1 1
   # Handle error
Version History
2019
