*transparencyvalue
Sets the level of transparency for the shaded surface in components that are set to be transparent.
*transparencyvalue value
HyperMesh Tcl Modify Command
value
A value from 0 to 10, 0 being the most transparent and 10 being opaque.
To set the transparency level to completely transparent:
*transparencyvalue (0
None.
