*hf_Addendum_UpdateSlide
Update the handle position.
*hf_Addendum_UpdateSlide handle_id x_coord y_coord z_coord tol
HyperMesh Tcl Modify Command
This command updates the position of handle with ID handle_id from its current position, to the new position with coordinate x_coord, y_coord, and z_coord.
handle_id
Handle ID.
x_coord
X coordinate of the new handle position.
y_coord
Y coordinate of the new handle position.
z_coord
Z coordinate of the new handle position.
tol
Dummy double value. Should always be 1.0.
To update the position of the handle with ID 5:
*hf_Addendum_UpdateSlide 5 1982.39933 287.781925 -36.9308916 1.
   # Handle error
