*set_preserved_edges
Marks edge geometry to be preserved during batch meshing, or clears the "preserved" flag from preserved edges.
*set_preserved_edges hmlinesmark new_stat
HyperMesh Tcl Modify Command
hmlinesmark
The mark containing the lines that you wish to flag as preserved or not preserved. 0 indicates all lines.
new_stat
1 - The lines are marked as preserved.
0 - The preservation flag is cleared from the lines.
To preserve the lines in mark 2:
*set_preserved_edges(2,1)
None.
