*showview
Shows the entities with respect to a view saved using *saveviewmask.
*showview name entity_type_id
HyperMesh Tcl Modify Command
name
The name of the view to show.
entity_type_id
The entity type ID to show.
Examples
Show the comps (entity type ID 3) in view View2:
*showview View2 3
   # Handle error
Version History
2020
