*createfbdfilefromfbdsummarytable
Creates a .fbd file from an FBD summary table.
*createfbdfilefromfbdsummarytable filepath=<value> summPt_systemId=<value> summaryTable_name=<value>
HyperMesh Tcl Modify Command
filepath=<value>
The full name and path of the .fbd file to write.
The ID of the system to resolve the summation.
The name of the FBD summary table created by *createfbdsummarytable.
To write the FBD file to C:/temp/my_fbd.fbd using system ID 2 and summary table FBDSummary_Run1:
*createfbdfilefromfbdsummarytable C:/temp/my_fbd.fbd 2 FBDSummary_Run1
   # Handle error
Version History
2019.1
