*orient_normals_outside_solid
Re-orients the normals of a solid inside or outside, depending on the orientation flag.
*orient_normals_outside_solid mark_id orientation
HyperMesh Tcl Modify Command
This command re-orients the normals of a solid inside or outside, depending on the orientation parameter.
mark_id
The mark of solids selected for orientation. Valid values are 1 and 2.
orientation
The value of orientation.
  • 0 - Orient normals outside solid
  • 1 - Orient normals inside solid
To orient the normals for all solids toward the inside:
*createmark solids 1 all
*orient_normals_outside_solid 1 1
   # Handle error
Version History
9.0
