*interfaceaddsolidface
Creates interface elements on shell elements and faces of solid elements.
*interfaceaddsolidface name master element mark node mark break angle
HyperMesh Tcl Modify Command
name
The name of the group into which the interface elements should be placed.
master
Use 1 for master; 0 for slave.
element mark
The ID of the mark containing the solid elements.
node mark
The ID of the mark containing nodes that define the face of a solid element.
break angle
The angle used to define a "sharp corner".
HyperMesh will use the node mark to find the face of a solid element. All adjacent faces will then be found until a sharp corner (defined by a break angle) is found. Finally, master/slave elements will be created on these faces.
None.
