*currentcollector
Sets the current collector.
*currentcollector entity type name
HyperMesh Tcl Modify Command
entity type
Collector type which the current collector should be set to. Valid types are:
  • component
  • systcol
  • loadcol
name
The name of the collector which should be made current.
Examples
To set the current component to be the component named stuff:
*currentcollector(component,stuff)
