*edgesmarkrestorejoints
Restores previously suppressed fixed points on edges.
*edgesmarkrestorejoints mark_id
HyperMesh Tcl Modify Command
This command restores previously suppressed (by using *verticesmarksuppress) fixed points on selected surface edges.
mark_id
The mark ID of input surface edges. Valid values are 1 and 2.
To restore fixed points on surface edge 99:
*createmark lines 1 99
*edgesmarkrestorejoints 1
   # Handle error
Version History
12.0.110
