*AE_AttachmentControlDefaultCreate
Initializes the attachment control defaults.
*AE_AttachmentControlDefaultCreate reserved1 reserved2
HyperMesh Tcl Modify Command
Initializes the attachment control defaults. Must be called before any attachment controls can be used or saved.
reserved1
Reserved for future use, must be set to "".
reserved2
Reserved for future use, must be set to 1.
Examples
Create an attachment control named "myattachmentcontrol", derived from the rigid spider default:
*AE_AttachmentControlDefaultCreate "" 1
*AE_AttachmentControlCreateFromDefault "myattachmentcontrol" "rigidspider" 1
   # Handle error
Version History
2020
