*midsurface_collapse_lines
Sets the selection of lines to be collapsed during mid-surface extraction when performing a rerun operation.
*midsurface_collapse_lines mark_id
HyperMesh Tcl Modify Command
mark_id
The ID of the mark containing the lines to collapse. Valid values are 1 and 2.
To set the lines with IDs 5-7 to collapse during the mid-surface extraction when performing a rerun operation:
*createmark lines 1 5 6 7
*midsurface_collapse_lines 1
   # Handle error
Version History
13.0
