*elementqualityoptimizenodenew
Optimizes a node location to improve the attached elements' quality index according to pre-set quality criteria.
*elementqualityoptimizenodenew node_id midnodes_flag optimize_flag
HyperMesh Tcl Modify Command
This command optimizes a node location to improve the attached elements' quality index according to pre-set quality criteria.
This command only functions between an *elementqualitysetup command and an *elementqualityshutdown command.
Current element quality criteria for optimization must be set before using this command. The command may be applied at any time without resetting the current quality criteria.
node_id
The node ID.
midnodes_flag
Neighboring mid-nodes during optimization.
  • 0 - Do not consider neighboring.
  • 1 - Consider neighboring.
optimize_flag
Optimize the node location.
  • 1 - Along the surface.
  • 2 - Normal to the surface.
  • 3 - Along and then normal to the surface.
To optimize the location of the nodes with ID's 102, 397 and 432 using quality criteria from a file:
*readqualitycriteria c:/criteria/mycriteria.txt
*createmark elems 1 displayed
*elementqualitysetup 1
*elementqualityoptimizenodenew 102 1 1
*elementqualityoptimizenodenew 397 0 2
*elementqualityoptimizenodenew 432 1 1
*elementqualityshutdown 1
   # Handle error
Version History
12.0.110
