*markprojecttomanysurfaces
Projects entities to multiple surfaces.
*markprojecttomanysurfaces <option1>=<value1> <option2>=<value2> ... <optionN>=<valueN>
HyperMesh Tcl Modify Command
Projects entities to multiple surfaces. The entities are projected to the surface closest to it along a given vector, or normal to the surface.
All options may be specified in any order.
ProjectionType=<value>
1 - Project by vector
To project along a vector given its 3 components along x, y and z directions, VectorXComp, VectorYComp, and VectorZComp are used.
To project along a vector defined by 2 nodes VectorNode1Id and VectorNode2Id are used.
To project along a vector normal to the plane defined by 3 nodes VectorNode1Id, VectorNode2Id and VectorNode3Id are used.
2 - Project normal to surfaces
SourceEntityType=<value>
The entity type to project. Valid values are elements, nodes and points. This is a mandatory option.
SourceEntityTypeMarkId=<value>
The ID of the mark of entities to project. Must be set to 1. This is a mandatory option.
TargetEntityType=<value>
The entity type to project onto. Valid values are surfaces. This is a mandatory option.
TargetEntityTypeMarkId=<value>
The ID of the mark of entities to project onto. Must be set to 2. This is a mandatory option.
VectorNode1Id=<value>
The ID of the first vector node. Valid only when ProjectionType=1.
VectorNode2Id=<value>
The ID of the second vector node. Valid only when ProjectionType=1.
VectorNode3Id=<value>
The ID of the third vector node. Valid only when ProjectionType=1.
VectorXComp=<value>
The x component of the vector. Valid only when ProjectionType=1.
VectorYComp=<value>
The y component of the vector. Valid only when ProjectionType=1.
VectorZComp=<value>
The z component of the vector. Valid only when ProjectionType=1.
Examples
Project nodes 1575-1674 to surfaces 17-19 along the vector (5.7, 0, 9.5):
*createmark nodes 1 1575-1674
*createmark surfaces 2 17-19
*markprojecttomanysurfaces SourceEntityType=nodes SourceEntityTypeMarkId=1 TargetEntityType=surfs TargetEntityTypeMarkId=2 ProjectionType=1 VectorXComp=5.7 VectorYComp=0 VectorZComp=9.5
Project elements 123-168 to surfaces 7-10 along the vector given by nodes 1798 and 1820:
*createmark elements 1 123-168
*createmark surfaces 2 7-10
*markprojecttomanysurfaces SourceEntityType=elems SourceEntityTypeMarkId=1 TargetEntityType=surfs TargetEntityTypeMarkId=2 ProjectionType=1 VectorNode1Id=1798 VectorNode2Id=1820
Project points 136-140 to surfaces 15 and 16 normal to the plane given by nodes 1200, 1208 and 1210:
*createmark points 1 136-140
*createmark surfaces 2 15 16
*markprojecttomanysurfaces SourceEntityType=points SourceEntityTypeMarkId=1 TargetEntityType=surfs TargetEntityTypeMarkId=2 ProjectionType=1 VectorNode1Id=1200 VectorNode2Id=1208 VectorNode3Id=1210
Project nodes 136-140 normally to surfaces 15 and 16:
*createmark nodes 1 136-140
*markprojecttomanysurfaces SourceEntityType=points SourceEntityTypeMarkId=1 TargetEntityType=surfs TargetEntityTypeMarkId=2 ProjectionType=2
   # Handle error
Version History
2020
