*add_remove_distance_manipulator
Adds or removes distance (dimension) manipulators between two surface vertices.
*add_remove_distance_manipulator mode point_id1 point_id2 lock_turnover reserved
HyperMesh Tcl Modify Command
Adds or removes distance (dimension) manipulators between two surface vertices. The manipulators are displayed upon entering the Dimensioning panel.
mode
The mode to use:
  • 0 - Remove the distance manipulator between the two points.
  • 1 - Add a distance manipulator between the two points.
  • 2 - Remove all distance manipulators.
point_id1
The first vertex point ID. Only used when mode is 0 or 1.
point_id2
The second vertex point ID. Only used when mode is 0 or 1.
lock_turnover
Specifies the end point lock controls which determine which manipulator side surfaces are selected automatically and what end(s) are movable. The value specified overwrites the area_selection_ratio constraint but cannot overwrite the max_pick_angle constraint. If the latter constraint does not allow the sides (point_id1 and point_id2) to move, or allows only one side to move, only the allowed side will move, regardless of this parameter.
Bit values are used and the value is calculated as (Bit0 + 2*Bit1 + 4*Bit2).
Bit0
0 - The point with the smaller ID cannot move during offset. Only valid when Bit2 is set to 1.
1 - The point with the smaller ID can move during offset. Only valid when Bit2 is set to 1.
Bit1
0 - The point with the larger ID cannot move during offset. Only valid when Bit2 is set to 1.
1 - The point with the larger ID can move during offset. Only valid when Bit2 is set to 1.
Bit2
0 - Do not edit the lock controls and ignore Bit0 and Bit1.
1 - Edit the lock controls based on Bit0 and Bit1 values.
reserved
Reserved for future use. Must be specified as 0.
Examples
To add a distance manipulator between vertices 100 and 101:
*add_remove_distance_manipulator 1 100 101 7 0
To remove a distance manipulator between vertices 100 and 101:
*add_remove_distance_manipulator 0 100 101 0 0
To remove all distance manipulators:
*add_remove_distance_manipulator 2 0 0 0 0
   # Handle error
Version History
11.0
