*splitelementbyelemselect
Splits shell element patches using patterns based on the patch shared edges.
*splitelementbyelemselect mark_id
HyperMesh Tcl Modify Command
mark_id
The ID of the mark of elements to split. Valid values are 1 and 2.
Examples
Example:
*createmark elements 1 4495 4505 4513 4521 4522 4531 4540 4553 4564 4575
*splitelementbyelemselect 1
   # Handle error
Version History
2021
