*morphconstraintupdatesmooth
Creates a smooth type morphconstraint for the selected nodes.
*morphconstraintupdatesmooth nlist type closed mcon color
HyperMesh Tcl Modify Command
This command updates a smooth type morphconstraint for the selected nodes. During morphing, the perturbations of the nodes or dependent handles will be modified using a spline based approximation so that edge domains running along the selected entities will have smooth contours.
nlist
The ID of the list containing the nodes. Valid values are 1 and 2.
type
0 - Apply to nodes. All handles on the node list serve as anchors for the spline curve and nodes are adjusted to the curve based on influences
1 - Apply to dependent handles. Only the independent handles on the node list serve as anchors and the dependent handles are adjusted to the curve based on influences
closed
0 - Open ended
1 - Loop. The first node on the list will be added to the end to form a loop
mcon
The ID of the morph constraint to update.
color
The color of the constraint. Valid values are 1 through 64.
To update a smooth morphconstraint for nodes 1-5 with a closed loop:
*createlist nodes 1 1 2 3 4 5
*morphconstraintupdatesmooth 1 0 1 12 32
   # Handle error
