*realizesolvermassestomasselements
Creates mass elements from solver mass entities.
*realizesolvermassestomasselements mark_id
HyperMesh Tcl Modify Command
This is mainly useful in solver conversion from LS-DYNA to other solvers that support nodal mass elements.
mark_id
The ID of the mark of solver masses of type NODE or NODE_SET to realize.
Examples
To convert all the nodal solver masses:
*createmark solvermasses 1 "by config" 105
*realizesolvermassestomasselements 1
   # Handle error
Version History
2020.1
