*CE_GlobalSetDouble
Set global double parameters relating to the display of connectors.
*CE_GlobalSetDouble name value
HyperMesh Tcl Modify Command
This command sets global double parameters to control the display of connectors.
name
The name of the parameter to set:
g_ce_size
Determines the display size of connectors.
Range > 0.0
value
The double value to set for the name parameter.
Examples
To set the global connector display size to 2.0:
*CE_GlobalSetDouble g_ce_size 2.0
Version History
9.0
