*shapevarcreate_xproduct
Creates a shape variable by using the cross product of two other shape variables.
*shapevarcreate_xproduct basenode shape variable A shape variable B magnitude
HyperMesh Tcl Modify Command
basenode
The ID of the node where the base of the result is located after it is created.
shape variable A
The ID of the first shape variable in the cross product.
shape variable B
The ID of the second shape variable in the cross product.
magnitude
Magnitude of resulting vector.
None.
