*midsurface_remove_edge_target_by_number
Removes a target from a surface edge specified by a line number.
*midsurface_remove_edge_target_by_number face e1_line_number
HyperMesh Tcl Modify Command
face
The index of the surface to offset.
e1_line_number
The edge from which targets are to be removed.
You cannot manually employ this command, because HyperMesh must internally generate the index values (they cannot simply be typed in).
None.
