*BCM
Creates loads by performing linear interpolation between existing loads or loads defined in a text file.
*BCM entity_type mark_id load_mark_id config type filename tolerance facenode_mark_id break_angle
HyperMesh Tcl Modify Command
This command creates loads by interpolating between existing loads (field loads) or loads defined in a text file (linear interpolation).
entity_type
The type of entity to create loads on. Valid values are nodes and elements.
mark_id
The ID of the mark containing the entities to create the loads on. Valid values are 1 and 2.
load_mark_id
The ID of the mark containing any existing loads to use during the interpolation. The mark does not have to be populated. Valid values are 1 and 2.
config
The configuration of the load to create. Valid values are:
1 - forces
2 - moments
4 - pressures
5 - temperatures
6 - fluxes
type
The solver type of the load to create. This value is dependent on the current solver template loaded.
filename
The name and path of a file containing the coordinates and values of any input loads to use for the linear interpolation. This parameter is optional and should be set to "" if not specified. The format of the file is:
x y z value
x y z value
etc…
tolerance
The search radius to use for finding nodes/elements for interpolation. If a negative value is provided, gap filling is used and a load is created at every selected node/element regardless of the search tolerance.
facenode_mark_id
The ID of the mark containing the face nodes when defining solid element faces. The mark does not have to be populated. Valid values are 0 (when entity_type is set to nodes), 1 and 2.
break_angle
The break angle to use when defining solid element faces. Should be set to 0 when entity_type is set to nodes.
Examples
To create forces on nodes 100, 101 and 102 by interpolating from existing loads on nodes 99 and 103, using a search radius of 10.0:
*createmark nodes 1 101-102
*createmark loads 2 99 103
*BCM nodes 1 2 1 1 "" 10.0 0 0 0
To create forces on nodes 100, 101 and 102 by interpolating from loads defined in the file C:/my_loads.txt, using a search radius of 10.0:
*createmark loads 2
*BCM nodes 1 2 1 1 "C:/my_loads.txt" 10.0 0 0
   # Handle error
