*morphmapedgestosurfaceoffset
Maps selected morph volume edges to the specified surfaces.
*morphmapedgestosurfaceoffset user_mark_id entity_type mark_id use_symmetry use_constraints project vector_id number_of_mid_handles offset
HyperMesh Tcl Modify Command
This command will project the handles on the marked morph volume edges to the surfaces on the mark along the specified vector, surface normal, or normal to any attached shell elements (unusual for morph volume edges).
user_mark_id
The ID of the user mark containing the morph edges. Valid values are 0-3.
entity_type
Must be set to surfs.
mark_id
The ID of the mark containing the input surfaces. Valid values are 1 and 2.
use_symmetry
0 - Do not use symmetry links
1 - Use symmetry links
use_constraints
0 - Do not use constraints
1 - Use constraints
project
0 or 10 - Project along vector defined by vector_id
1 or 11 - Project normal to surfaces
2 or 12 - Project normal to attached shell elements
If offset is non-zero, the offset will be measured from the closest point on the surfaces for values of 0, 1 and 2. The offset will be measured along the projection vector or normal for values of 10, 11, and 12.
vector_id
The ID of vector created using *createvector for the projection direction. Must be set to 1.
-1 - Do not change the handles on the edges
0 - 5 - Update the number of mid-handles on the edges to this number
offset
The distance to offset nodes from the target.
The offset will be measured from the closest point on the surfaces for values of project of 0, 1, and 2. The offset will be measured along the projection vector normal for values of project of 10, 11, and 12.
Examples
To map edges on mark 0 to a surface along a vector with offset of 1.2 and leaving the handles unchanged:
*morphmanageedgemark 0 0 3
*morphmanageedgemark 2 0 1
*morphmanageedgemark 4 0 1
*createmark surfs 1 1
*createvector 1 1.0 0.0 0.0
*morphmapedgestosurfaceoffset 0 surfs 1 1 1 0 1 -1 1.2
To map edges on mark 1 to a surface along the surface normal with 3 mid-handles per edge:
*morphmanageedgemark 0 1 3
*morphmanageedgemark 2 1 1
*morphmanageedgemark 4 1 1
*morphmapedgestosurfaceoffset 1 surfs 1 1 1 1 1 3 0.0
   # Handle error
Version History
14.0.110
