*morphcreatedomaindc
Creates a domain from the elements on the mark with various options.
*morphcreatedomaindc elemtype elemmark type part rethand bydom bycomp
HyperMesh Tcl Modify Command
elemtype
ELEMS
elemmark
Element mark number
type
-1 - Autoupdate
11 - D domain
22 - D domain
33 - D domain
6 - Local domains (1D, 2D, and 3D)
7 - General domain
part
0 - Do not use partitioning
1 - Partition all domains
2 - Only partition elements on solid domains (only for type = 6)
rethand
0 - Do not retain handles
1 - Retain handles
bydom
0 - Do not divide selected elements by existing domain
1 - Divide elements by existing domains
bycomp
0 - Do not divide selected elements by components
1 - Divide selected elements by components
*morphcreatedomaindc (ELEMS,1,2,1,1,0,0)
A new domain is created from the elements on the mark. The type specified notes which elements in the mark will be retained. If no elements of the correct type are on the mark, the command will exit. Elements from existing domains may be placed on the mark and will be removed from their former domain and placed in the new domain.
   # Handle error
