*createlist
Creates an ordered list of entities for use in a subsequent command.
*createlist entity_type list_id ?"by model" <model_name>? entities
HyperMesh Tcl Modify Command
entity_type
Entity type to put on the list. Valid values are elems, laminates, lines, nodes, plies and surfs.
list_id
The ID of the list to populate. Valid values are 1 and 2.
The optional model to create the list from. If not specified, the current model is used.
entities
The ID of the entities, in the appropriate order.
Examples
To create a line from nodes 2, 10, and 3:
*createlist nodes 1 2 10 3
*linecreatefromnodes 1 0 150 5 179
To create, query, and clear a list from nodes 2, 10, and 3 for model model-2:
*createlist nodes 1 "by model" model-2 2 10 3
set my_list [hm_getlist nodes 1 0 model-2]
*clearlist nodes 1 "by model" model-2
   # Handle error
Version History
2020 - Added new option "by model".
