*attributeupdateintarray2d
Updates an attribute of type 2D int array.
*attributeupdateintarray2d entity type id identifier solver status behavior data rows cols
HyperMesh Tcl Modify Command
entity type
The type of entity that owns the attribute.
id
The ID of the entity
identifier
The identifier of the attribute.
solver
The solver number of the attribute.
status
The status of the attribute.
behavior
The behavior of the attribute.
data
The 2D array of ints.
rows
The number of rows in the array.
cols
The number of columns in the array.
Examples
Update an attribute of type 2D int array to [1,2,3] on the material with ID 7.
[4,5,6]
*createintarray2d(2,3) 1,2,3,5,6,7
*attributeupdateintarray2d(materials,7,615,2,2,0,1,1)
