*createcollectorforpartiallycontained
Creates a collector and moves certain entities into the collector.
*createcollectorforpartiallycontained entity_type mark_id name config type reserved
HyperMesh Tcl Modify Command
entity_type
Entity type to move into the collector. Valid values are:
  • elems
  • loads
  • systs
  • vectors
mark_id
The mark ID containing the entities to move. Valid values are 1 and 2.
name
The new collector name. The collector type is determined by the entity_type.
config
Set to a valid config value to specify if only entities of that config should be moved. Otherwise, set to 0.
Currently only supported for elements.
type
Set to a valid type value to specify if only entities of that type should be moved. Otherwise, set to 0.
reserved
Reserved for future use. Must be set to 0.
Examples
To create a component named comp2 and move elements 1-100:
*createmark elems 1 1-100
*collectorcreateforpartiallycontained elems 1 comp2 0 0 0
To create a component named comp2 and move only quad elements from elements 1-100:
*collectorcreateforpartiallycontained elems 1 comp2 104 0 0
   # Handle error
Version History
11.0.101
