*saveviewmask
Saves the current view orientation and visible entities.
*saveviewmask view_name visible
HyperMesh Tcl Modify Command
Saves the currently view orientation and visible entities. Views are stored in the database.
view_name
The name of the view to save. The numbers 1-5 are reserved and cannot be used.
visible
A flag indicating whether to save the visible entities or not. Valid values are:
  • 0 - Save the visible entities and view orientation.
  • 1 - Save only the view orientation.
To save a view with the visible entities, with the name "my_view":
*saveviewmask "my_view" 0
   # Handle error
