*createentitysameas
Create a new entity that is a clone of a source entity.
*createentitysameas entity_type entity_id
HyperMesh Tcl Modify Command
Create a new entity that is a clone of the original. Attributes and data names are both cloned, however, collected entities are not cloned along with collectors.
There are also a few limitations to this command:
  • Rigid wall entities are not supported.
entity_type
Entity type to use as source.
entity_id
The ID of the source entity to clone.
Examples
To duplicate the component with ID 100:
*createentitysameas comps 100
   # Handle error
Version History
13.0
