*transparencymark
Makes the shaded surfaces in components on the mark transparent.
*transparencymark mark
HyperMesh Tcl Modify Command
mark
The mark containing the components that will be transparent.
To make the shaded surfaces in the components on the mark transparent:
*settransparency(1)
*createmark(components,1) "middle"
*transparencymark(1)
*createmark() is required for this command.
None.
