*morphdeletemvedgenodes
Deletes the selected mid-edge nodes from the edges of morph volume.
*morphdeletemvedgenodes entity_type mark_id
HyperWorks Tcl Query Command
This command will remove the specified mid-edge nodes which govern the shape of a morph volume edge. The edges will then be refit to follow the shape of the remaining nodes, which may change the shape of the morph volume. Nodes at the ends of edges may not be deleted and will be ignored by this command. The nodes to be removed may be specified either by the nodes or the handles on those nodes.
Note: Updating the nodes for a morph volume will not morph the registered nodes.
entity_type
Valid values are nodes or handles.
mark_id
The mark ID containing either nodes or handles. Valid values are 1 and 2.
Examples
To delete all mid-edge nodes in the model:
*createmark nodes 1 "all"
*morphdeletemvedgenodes nodes 1
To delete a handle and the underlying node from an edge:
*createmark handles 1 13
*morphdeletemvedgenodes handles 1
   # Handle error
Version History
10.0
