*rigid
Creates a rigid element between two nodes.
*rigid node1 node2 dofs
HyperMesh Tcl Modify Command
node1
The independent node of the element.
node2
The dependent node of the element.
dofs
The degrees of freedom for which the element is active (any of the digits 1-6).
To create a rigid element between nodes 100 and 101 in all six degrees of freedom:
*rigid(100,101,123456)
s
None.
