*graphuserwindow_to_XYZ
Re-centers the display on a specified point, using a specified number of animation steps to do so.
*graphuserwindow_to_XYZ x y z n
HyperMesh Tcl Modify Command
Re-centers the display on a specified point, using a specified number of animation steps to do so. This command differs from *graphuserwindow_byXYZandR() in that the re-center action is not instantaneous; the user’s view pans to the selected point at a specified rate, providing a sense of relative location between the original viewpoint and the new one.
x
The x coordinate of the specified point.
y
The y coordinate of the specified point.
z
The z coordinate of the specified point.
n
The number of frames of animation to use when panning from the original view point location to the new one.
To re-center the view on a point with coordinates (20, 15.3, and 72) and show 30 steps of the movement involved:
*graphuserwindow_to_XYZ(20,15.3,72,30)
