*add_multi_washer_elements
Adds washer elements to circular holes of shell meshes.
*add_multi_washer_elements node_mark_id feature_angle string_array number_of_strings periphery_node_mark_id background_elem_mark_id rigid_spider local_cordinate_system
HyperMesh Tcl Modify Command
This command is used to add washer elements to circular holes of shell meshes. Multiple holes can be handled at a time.
node_mark_id
The mark of nodes on the circular holes to add washers to. Valid values are 1 and 2.
feature_angle
Defines the mesh feature lines around washer elements. The range should be (0, 180). It is usually set to 30.
string_array
The string array ID that contains the washer element information. The string array is created using the *createstringarray command. This should always be set to 1.
The first string in quotations should contain the following parameters as keywords followed by the parameters values. Keywords and the corresponding values can be separated by blanks and/or by "=":
layer_number <layers>
The number of washer element layers, > 0.
uniform_layers <flag>
The value is 1 or 0. 1 means that all layer widths are uniform.
hole_density <value>
The washer element density on the hole.
All other strings define layer width parameter groups. If uniform_layers is set to 1, only one layer width parameter group is needed. Otherwise, the number of groups should be the same as the layer number. Each group contains 2 quoted values:
width_flag <flag>
1 - The width_value defines the width of the layer, otherwise it is defined as the ratio of the layer width over the hole radius.
width_value <value>
Defines the width of the layer.
number_of_strings
Integer indicating the size (number of strings) in the string array created using *createstringarray.
The output mark of periphery nodes generated on the hole. Valid values are 0, 1 and 2.
0 - No periphery nodes are placed on the mark.
The output mark of background elements to be deleted in order to update the connectivity of the newly created elements and their neighbors. Valid values are 0, 1 and 2.
0 - Background elements are deleted and element connectivity is updated. Otherwise, the background elements are kept and placed on the mark.
rigid_spider
Valid values are 0, 1 and 2. If the value is set to 0, no rigid elements will be created inside the hole.
1 - A single spider will be created inside the hole.
2 - Individual rigid elements will be created for periphery nodes.
1 - A local coordinate system will be created in the plane of the hole.
Examples
To add washer elements around the hole containing node 60, using 2 element layers of uniform size, a density of 8 and a width of 5.0:
*createmark nodes 1 60
*createstringarray 2 "layer_number = 2 uniform_layers = 1 hole_density = 8"  "1 5.0"
*add_multi_washer_elements 1 30 1 2 0 0 1 1
   # Handle error
Version History
13.0
